07-17-2012 02:53 AM - last edited on 03-25-2019 07:02 PM by ciscomoderator
hi,
How to integrate CME 8.6 with Nortal Digital PBX. What are the requirement to connect Nortal PBX to CME.
07-17-2012 07:44 AM
Well, if the nortel can support IP, then you can use SIP (or H.323), otherwise ISDN PRI will be the best option.
Hope to help,
Adrian.
07-17-2012 11:12 AM
Hi Shaik,
In addition to the great tips from Adrian (+5 "A")
I thought the CME Inter-op guides might be helpful as well;
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
