connecting several ata 186
I had connected two ata 186,but i can not connect them all together as i peer to peer network with dial plan
what do i need to connect several ata 186 devices with dial plan as a peer to peer network?
anyone can call anyone
gatekeeper or call manager or both ones?
thanks
1 REPLY
Re: connecting several ata 186
You can use a GKeeper or define the ATA as a Gateway H323 in the CM. I tested both and worked fine.
112
