Connection between Cisco Router and Ericsson BP250 Using PRI
We are connecting an IP Telephony system into an Ericsson BP250 via a 1760 router with a PRI interface. We have successfully connected the systems together physically - clocks are OK and Framing is OK. We can make a call from the IP Telephony system into the PABX. The call is correctly delivered to the PABX and the handset rings and a voice path established. There are no issues apparent from reading the Q.921 and Q.931 debugs.
The problem I have is that when the PABX is placing a call to the router. The debug of these calls show that dialling the access code for the tie-line results in a CALL SETUP message with no digits. The router just gives dial tone to the caller, who then tries to dial the number of the required extension sending the DTMF tones, but of course the router cannot interpret them.
The PABX guys seem to be having trouble understanding how to configure the BP250 to send digits in the CALL SETUP request.
Has anyone had experience in working with the BP250?
I should add that the problem would seem to be peculiar to that box and the way it is configured as we have a number of other successful ISDN and QSIG implemetations to Ericsson systems but these are connecting to MD110 switches.
Re: Connection between Cisco Router and Ericsson BP250 Using PRI
hi,
i don't know if this will help but have you tried putting the "isdn overlap-receiving" command on your router (this command is put under the interface eg s1/0:15)
or make sure that you're pbx provider sends all digits at the same time
hope this helps
dave
Dave
thanks for the tips. We have overlap-receiving on. It does not matter however, as there are no digits being sent by the PABX. (traces show only the CALL SETUP. there are no subsequent INFORMATION ffarmes that may be carrying digits)
Anthony
Thanks, It worked for me
It worked for me
625
