Community Member
Connection between R2 and ISDN
dear all
I am trying to connect two AS5300, one connected with an ISDN and other using R2. And I have some problem when the isdn side call a certain number at R2 side.
As ISDN error I have:
Cause i = 0x80E0 - Mandatory information element missing
does some one knows how I can solve this problem ?
here are the config and log error
ERROR:
Feb 25 14:12:12.130: ISDN Se1:23 Q931: RX <- SETUP pd = 8 callref = 0x0013
Bearer Capability i = 0x8090
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xE9808381
Exclusive, Interface 0, Channel 1
Called Party Number i = 0x80, '011XXXXXXXXXX'
Plan:Unknown, Type:Unknown
*Feb 25 14:12:12.134: ISDN Se1:23 EVENT: process_rxstate: ces/callid 1/0x7E call
type 2 CALL_INCOMING
*Feb 25 14:12:12.134: ISDN Se1:23 EVENTd: calltrkr_incoming_call: call_id=0x7E
*Feb 25 14:12:12.134: ISDN Se1:23 EVENTd: calltrkr_setup_received: isdn_info=165
5802864l, call_id=0x7E ANSWER
*Feb 25 14:12:12.134: ISDN Se1:23 EVENTd: calltrkr_setup_received: calltracker d
isabled
4831212l, call_id=0x7E ANSWER
*Feb 25 14:12:12.138: ISDN Se1:23 EVENTd: call_incoming: b channel 0, call type
is VOICE ULAW
*Feb 25 14:12:12.138: ISDN Se1:23 EVENTd: call_incoming: Received a VOICE call f
rom <unknown> on b channel 0 at 64 Kb/s
*Feb 25 14:12:12.154: ISDN Se1:23 EVENTd: process_pri_simple: msg 74, call id 0x
7E, bchan 0, call type VOICE
*Feb 25 14:12:12.154: ISDN Se1:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x8013
Channel ID i = 0xA98381
Exclusive, Channel 1
*Feb 25 14:12:12.342: ISDN CDAPI: cdapi_find_tsm found a GTD message IAM,
GCI,f7dd958e480111d78147d0318cbbc656
ip011XXXX21XXX37:
end of gtd length is 46
*Feb 25 14:12:22.150: ISDN Se1:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x001
*Feb 25 14:12:22.150: ISDN SERROR: LIF_StopTimer: NULL timer
*Feb 25 14:12:22.150: ISDN Se1:23 EVENT: process_rxstate: ces/callid 1/0x7E call
type 2 CALL_DISC
*Feb 25 14:12:22.150: ISDN Se1:23 EVENTd: process_rxstate: cause=0x10 (16), caus
e_present=1
*Feb 25 14:12:22.150: ISDN Se1:23 EVENTd: calltrkr_call_disconnected: isdn_info=
0x62B18BF0, call_id=0x7E
0x62A2B86C, call_id=0x7E
*Feb 25 14:12:22.154: ISDN Se1:23 CDAPI: cdapi_mib_update msg CALL_DISC, remote
number , connected? No
*Feb 25 14:12:22.154: ISDN Se1:23 EVENTd: process_disc_ack: call id 0x7E, ces 1,
call type VOICE cause 0x10
*Feb 25 14:12:22.154: ISDN Se1:23 Q931: RX <- RELEASE pd = 8 callref = 0x0013
*Feb 25 14:12:22.154: ISDN Se1:23 Q931: TX -> RELEASE pd = 8 callref = 0x8013
*Feb 25 14:12:22.158: ISDN SERROR: LIF_StopTimer: NULL timer
*Feb 25 14:12:22.158: ISDN Se1:23 EVENT: process_rxstate: ces/callid 1/0x7E call
type 2 CALL_CLEARED
*Feb 25 14:12:22.158: ISDN Se1:23 EVENTd: calltrkr_call_cleared: isdn_info=0x62B
18BF0, call_id=0x7E
*Feb 25 14:12:22.158: ISDN Se1:23 EVENTd: calltrkr_call_cleared: isdn_info=0x62A
2B86C, call_id=0x7E
*Feb 25 14:12:22.158: ISDN Se1:23 CDAPI: cdapi_mib_update msg CALL_DISC, remote
*Feb 25 14:12:22.162: ISDN Se1:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8
013
here is the config of ISDN side:
Building configuration...
Current configuration : 4382 bytes
version 12.2
boot system flash c5300-is-mz.122-13.t.bin
enable secret 5 XXXXXXXXXXXXXXXXXXX
enable password XXXXXXXXXXXXXXXXXXX
resource-pool disable
ip subnet-zero
isdn switch-type primary-5ess
voice call send-alert
voice rtp send-recv
voice class codec 55
codec preference 1 g729r8 bytes 50
codec preference 2 g729br8 bytes 50
codec preference 5 g723ar53
codec preference 7 g723ar63 bytes 144
codec preference 8 g723r53
codec preference 9 g723r63 bytes 120
!fax interface-type modem
mta receive maximum-recipients 0
controller T1 0
framing esf
clock source line primary
linecode b8zs
cablelength short 133
pri-group timeslots 1-24
no yellow generation
no yellow detection
controller T1 1
framing esf
clock source line secondary 1
linecode b8zs
no yellow detection
controller T1 2
shutdown
framing esf
linecode b8zs
no yellow detection
controller T1 3
shutdown
framing esf
linecode b8zs
no yellow detection
interface Ethernet0
ip address XXX.XXX.XXX.106 255.255.255.0
no ip mroute-cache
interface Serial0:23
no ip address
isdn not-end-to-end 64
isdn incoming-voice modem
isdn map address isdn plan isdn type unknown
isdn T310 5000
isdn send-alerting
isdn sending-complete
no cdp enable
interface Serial1:23
no ip address
isdn T310 5000
isdn send-alerting
no cdp enable
interface Serial2:23
no ip address
isdn switch-type primary-ni
no cdp enable
interface Serial3:23
no ip address
no cdp enable
interface FastEthernet0
no ip address
no ip mroute-cache
shutdown
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 XXX.XXX.XXX.1
no ip http server
call rsvp-sync
voice-port 0:D
bearer-cap Speech
voice-port 1:D
bearer-cap Speech
voice-port 2:D
voice-port 3:D
mgcp profile default
dial-peer cor custom
dial-peer voice 1000 pots
incoming called-number T
direct-inward-dial
dial-peer voice 597 voip
destination-pattern 011XXXXXXT
progress_ind progress enable 8
voice-class codec 55
session target ipv4:XXX.XXX.XXX.78
tech-prefix 1813#
gateway
line con 0
line aux 0
line vty 0 4
password 12345
login
end
Re: Connection between R2 and ISDN
Please turn on debug isdn q931 on the 5300. The output should lead you in the right direction.....
Community Member
here is the debug q931 and the cause seem to be:
*Feb 25 15:38:51.945: ISDN Se1:23 Q931: RX <- SETUP pd = 8 callref = 0x0045
Standard = CCITT
Channel ID i = 0xE9808383
Exclusive, Interface 0, Channel 3
Called Party Number i = 0x80, '01155842025426'
*Feb 25 15:38:51.965: ISDN Se1:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x8045
Channel ID i = 0xA98383
Exclusive, Channel 3
*Feb 25 15:39:01.973: ISDN Se1:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x004
*Feb 25 15:39:01.977: ISDN Se1:23 Q931: RX <- RELEASE pd = 8 callref = 0x0045
*Feb 25 15:39:01.977: ISDN Se1:23 Q931: TX -> RELEASE pd = 8 callref = 0x8045
*Feb 25 15:39:01.981: ISDN Se1:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8
045
*Feb 25 15:39:11.673: ISDN Se1:23 Q931: RX <- SETUP pd = 8 callref = 0x0046
Standard = CCITT
Called Party Number i = 0x80, '01155852436263'
*Feb 25 15:39:11.693: ISDN Se1:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x8046
*Feb 25 15:39:21.693: ISDN Se1:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x004
6
*Feb 25 15:39:21.697: ISDN Se1:23 Q931: RX <- RELEASE pd = 8 callref = 0x0046
*Feb 25 15:39:21.697: ISDN Se1:23 Q931: TX -> RELEASE pd = 8 callref = 0x8046
*Feb 25 15:39:21.701: ISDN Se1:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8
046
Yes, it does. Are you connected to a real 5ESS or something else? I would also suggest adding some sort of g711 codec to the codec class and see if that helps.
326
