Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
connection plar & ip ivr
To all GURUs
the scenario is this
nortel pabx --vg--call mgr--ip ivr
E1 CONFIG USED
************controller E1 7/6
************* ds0-group 1 timeslots 1-15,17-31 type fxs-ground-start
Problem scenario 1, we cannot make "incoming call" running even if we used dial peers (incoming to the ip ivr from the pabx side).
after using 'connection plar" & redirecting the call to the ip ivr number, it work. BUT, we can only hear the IP IVR prompt & could not interact with that (i mean sending or pressing any options).
are we on the right track? i mean it is ok to use "connection plar" for IP ivr apllication?
tks a lot
Anonymous
N/A
Re: connection plar & ip ivr
I don't think, using connection plar for IP ivr should cause any problem. I feel, there is some other problem. You can try some of these debugs and point out where exactly the error is occuring.This might help further troubleshooting.
debug modem csm
debug voip ccapi in
debug vtsp all
debug voip ivr
debug csm voice
debug csm modem
Thanks.
Do you have DTMF relay configured on your VoIP dial-peers that are pointing to CallManager?
Without it the IVR will not get information on the digits you key.
Could you post a sample of your VoIP dial-peers?
Justin
yes, we have a dial peer configuration.
pls see below dial peer
dial-peer voice 5000 pots
preference 1
destination-pattern 71T
progress_ind alert enable 8
port 7/6:1
dial-peer voice 5001 pots
preference 2
answer-address 8706
destination-pattern 88T
port 7/7:1
dial-peer voice 5002 pots
preference 2
port 7/7:1
dial-peer voice 5003 pots
preference 1
port 7/7:1
dial-peer voice 5004 voip
incoming called-number *
destination-pattern .
voice-class codec 1
session target ipv4:10.122.10.32
dtmf-relay rtp-nte h245-signal h245-alphanumeric
no vad
Blue
What is your IVR Route Point's DN? You shouldn't need a connection plar if your integration to the PBX is E1. For example, if your IVR Route Point is 5000, a PBX phone dials 5000, it hits the VG200 and the VG200 takes the digits 5000, matches your VOIP Dial peer (which you should change to something more specific than ".") and sends 5000 to CallManager. In your voip dial-peer try using one dtmf-relay option at a time. Also, make sure you have this command as well voice rtp send-recv One way voice could be your problem as well.
246
