Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Control Outgoing Calls on selective PRI lines
I have a setup as below:
2 PRI lines are terminated on the Cisco Gateway.
The gateway is connected to a CCM 5.0.
My requirement:I want all outgoing calls should be dialed out from a Particular PRI based on some logic.
How can I control the outgoing calls to be dialled out from a particular PRI based on my choice.
--Pranjol
Re: Control Outgoing Calls on selective PRI lines
Configure Route Groups and Route Lists (That's EXACTLY what they're for), if you need further explanation on this refer to the Dial Plan chapter of SRND
Dial Plan
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/srnd/5x/50dialpl_ps556_TSD_Products_Implementation_Design_Guide_Chapter.html
If H323 configure preference on dial-peers
java
if this helps, please rate
java
www.cisco.com/go/pdi
Are the 2 PRI's on the same gateway?
Please remember to rate useful posts, by clicking on the stars below.
Yes there will be 2 different PRI lines in the same gateway
in that case Route groups will not work if you persist on using h323, bcause you will be pointing to one IP address only.
what you could do is have your 0T (that is if you are requiring additional 0 for outside line, and dont do any digit stripping outbound on cucm). and have that point to only the PRI you want the call to be made on.
Simplest way is to use MGCP and have a route group consisting of only the PRI you want for outbound
there are more options with H323, but let me know if these meet your criteria
Is there any other way without using MGCP
Yes, with H323.
so you have your route group point to the one GW.
let;s say ion that you have 2 PRI's:
one on 0/1/0:15
one on 0/2/0:25
if you want all outgoing calls to go out you first PRI you just create a dial peer:
dialpeer voip 100 pots
destination-pattern 0T (or whatever your outbound pattern is)
port 0/1/0:15
and dont define the other PRI for outgoing
sorry, dialpeer voice 100 pots that is
Hall of Fame Super Gold
What is the criteria you want to use ?
Let me detail out my application requirement:
1)I have 2 PRI lines terminating on the same gateway
2)Based on the data extracted from CDR files and some application logic I want to force all outgoing calls through the least used PRI line.
For example PRI1 has got free 200 voice minutes and PRI2 has got 500 voice minutes.Hence all outgoing calls should be made via PRI2 till its free voice minutes is less than PRI1.
If free voice minutes of PRI2 is less than of PRI1 then calls should be made through PRI1.
Can I control this type of requirement through some configurations in the CCM with the help of some customized application developed using CUAE,AXL etc.
In that case, dial peers is not the solutions, i dont know what is
This is what hunt-group does automatically.
You use h.323 and place the teoPRi under hun-gtoup.
As hunt-scheme you specify least-used.
That's all.
Correction: I meant trunk-group, not hunt-group.
231
