conversation bleed to other ip phones
Several users have noticed that one phone in particular can be heard faintly in other earpieces. The local side of an off-net call is heard on some other phones. It sounds like bleed over on an analog phone line. I haven't found anything discussing bleed from one IP phone to another.
My 2811 is connected to a cisco 2924 switch, which is uplinked to a Linksys 24x1000BT switch. The phones are connected to the Linksys.
I'm having an issue setting up inter-VLAN routing on the 2924, which may be related to this issue.
As a test, I will move the 2811 into the Linksys and bypass the 2924.
Any ideas are welcome.
Re: conversation bleed to other ip phones
In my opinion this has to be in the pstn. What type of pstn connection do you have.
I have (2) 4-port FXO cards in my router, each connected to an individual POTS line. I will have to monitor now to see if the crosstalk is noticeable when I'm on an off-net call and hear another IP phone that is also on an off-net call.
Does that help?
300
