Converting 7912 SIP phones to SCCP
I am have few ip phones which are currently SIP phone and i wanna convert these phones to SCCP.
I was able to succefully convert the 7940 and 7960 to SCCP
I am unable to convert the 7912 sip phones to sccp .i need some help guys
I would appreciate if u guys can gimme a prompt response.
Cheers
Aj
Green
Re: Converting 7912 SIP phones to SCCP
The best to troubleshoot is using an sniffer trace,
How r u doing the conversion?
Make sure that you have in the tftp server the SCCP image, and then modify gkdefault.cfg file. Below is an example on what the file looks like.
> #txt
> # This file "gkdefault.txt" is provided as a convenience for upgrading the
> # Cisco 7912G IP Phone with minimal effort.
> # If changes are made to this file, you must run
> # again to create a new profile and place it in the TFTP directory.
> # If you plan to upgrade just one phone, you can copy gkdefault.cfg to
> # gk, where is the MAC address of the target phone, such
> # as gk001122334455.
> # The phone will try to download gk first, then gkdefault.cfg
> # if corresponding gk is not found on the TFTP server.
> upgradecode:3,0x601,0x0400,0x0100,0.0.0.0,69,0x030530B,CP79120101SCCP030530B.sbin
> # Set the GUI/Web config password to 1234; the password must NOT be 0
> # (disabled) if configuring via the phone's web interface is desired.
> #UIPassword:1234
Please refer below site for more information:
http://www.cisco.com/en/US/tech/tk652/tk701/technologies_tech_note09186a0080
094584.shtml
G
Hi ,
can you tell me how this file can be edited . i mean which part of the file to be edited and if needed wat need to be added or replaced in this file..
please let me know
thanks
AJ
Green
Will send u a sample config on Monday.
appreciated ...
thanks a lot
Can you pleae send me the sample config .. from the gkdefault what i have its still taking the SIP load
waiting for your reply
379
