Converting 7960 from SIP to SCCP
Have I got this right - I am trying a SIP to SCCP conversion for a 7960 using the following reference
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a008052dd88.html
The phone is presently loaded with
Application load P0S3-06-3-00
The router config is
tftp-server flash:P00307020400.loads
tftp-server flash:P00307020400.sb2
tftp-server flash:P00307020400.sbn
tftp-server flash:P00307020400.bin < -- tried it with and without the unsigned load
tftp-server flash:OS79XX.TXT
telephony-service
load 7960-7940 P00307020400
CME#more flash:OS79XX.TXT
P00307020400
It just keeps rebooting after it loads the OS79XX.TXT
TFTP: Looking for OS79XX.TXT
TFTP: Opened flash:OS79XX.TXT, fd 0, size 14 for process 60
TFTP: Finished flash:OS79XX.TXT, time 00:00:00 for process 60
.sbn11 06:03:51.615 UTC: TFTP: Looking for P00307020400
%LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1/2, changed state to down
%LINK-3-UPDOWN: Interface FastEthernet0/1/2, changed state to up
%DTP-5-TRUNKPORTON: Port Fa0/1/2 has become dot1q trunk
.sbn11 06:04:26.955 UTC: TFTP: Looking for P00307020400
%DTP-5-NONTRUNKPORTON: Port Fa0/1/2 has become non-trunk
thanks
1 REPLY
Blue
Re: Converting 7960 from SIP to SCCP
try to use a lowercase "p" in the filenames, ie:
tftp-server flash:p00307020400.loads
tftp-server flash:p00307020400.sb2
tftp-server flash:p00307020400.sbn
tftp-server flash:p00307020400.bin
i had similar symptoms. i noticed in debugs it's looking for "p00307020400...". i changed the filename from uppercase "P" to lowercase "p" and it worked!
also,
you've copied the P00307020400 files to the flash?
if so, attempt a new copy. perhaps something wrong with initial copy to the flash:.
178
