Converting 7960 MGCP to Skinny
Just wondering what the steps are for converting a 7960 ip phone from an MGCP load to a Skinny load and back again. I see the Tech Notes for SIP to Skinny, but not MGCP to Skinny.
Silver
Re: Converting 7960 MGCP to Skinny
If the phone is able to contact the CM, the CM should send the OS79XX.txt file across which contains the filename the handset should be running. If the current image name and the filename in the OS79XX file are different the handset should request the new image.
The phone is plugged into the same switch every other phone is plugged into. I'm not sure if you can delete the network config on the phone as you would on a Skinny phone, so that it can contact the CM. The message on the phone is "Configuring IP."
196
