that would require exporting the phone with the speed dials using BAT and all details option, exporting the phones you want to have the same SD, on the 2nd file change the speed dials using the info from the 1st file
then delete the phones and insert them again, there is no easy way to do this
javalenc
if this helps, please rate
java
