Corporate directory info display on 7960G
On our Cisco 7960G phone, when we hit corporate directory button, it shows three fields: LAST NAME, FIRST NAME, TEL NO. How to modify to populate other fields on the phone such as MANAGE USERID or DEPARTMENT etc? Is it possible? We are using CCMv4.1(3) and running embedded DC. Thanks.
Hall of Fame Super Silver
Re: Corporate directory info display on 7960G
You can identify the corresponding ASP page and modify it, however I'm not sure how it queries the CCM db, this data might be in different tables, so you will need to join the tables, etc. I'll try to identify the page for you later.
Chris
You can identify the corresponding ASP or JSP page and modify it, however I'm not sure how it queries the CCM db, this data might be in different tables, so you will need to join the tables, etc. I'll try to identify the page for you later.
Chris
117
