Corporate Directory Issues....loosing patience....:(
hello.
i'm still ( and repeatedly ) having problems with the ads-integration. after installing "IntegratedInstall224.exe" ( file i got from the last TAC-Case ), everything is working fine. some day, and out of nowhere, ( last time after i integrated a subscriber ) the connection breaks somewhere, resulting in the following error ,when i try to look at the user-directory. :
Basic Search
Error
The following error occurred while trying to load the requested page.
Couldn't create user object.[object Error] :
unfortunately i need this page to assign devices to one user, that connects via tapi ( ctiservice), and this does not work either.
i've resetted all the passwords in all the places mentioned in all the documents, de-installed the plugin, used CLEANDSA and AVVID_CFG, reinstalled the whole thing... and so on...
does not work. somewhere the while thing must be broken, BUT WHERE.
is there a sheet or similar availabe, that shows where the process of authentication goes which way, which com-objects are used by which user, and where to specify the passwords in the registry ??
thanks in advance
gerhard
Silver
Re: Corporate Directory Issues....loosing patience....:(
thanks, marina. i know all the documents, but there seems to be an error somewhere , where i cant find it...
bye
g
86
