Coverting from VoFR to VoIP using MC3810 Routers
We are currently running VoFR using 3810 routers. The remote sites have two FXS boards and the central site has 3810 with T1s connected to Central office PBX. We want to convert to VoIP what's the best way to migrate from FoFR to VoIP without losing communications between any of the remote sites. These sites talk to each other and to the central office.
Silver
Re: Coverting from VoFR to VoIP using MC3810 Routers
Providing the 3810's have 64meg of DRAM and 16 meg of flash you can load a 12.2T VOIP IP plus feature set. You can then run VOIP over frame relay.
You need a minimum of 16/64meg for VOIP, so if the routers don't have this then you won't be able to run VOIP
If you have 8MB of flash and 32 MB of DRAM, you can still run voip on a 3810 using a code that is IP Plus No ISDN. That should allow you to run voip on mc3810s.
I hope that helps.
Javed
74
