CPND Paramter q931 with Cisco AS5300
Good afternoon!
Have collided with a following problem. Is Cisco AS5300, to it are connected 4 ISDN E1 PRI a stream. The call comes, according to line Called Party Number from station Iskratel Si2000 23-25 digits come long approximately, whether after Cisco AS5300 comes only 15. there is what restriction or a problem on given version Cisco IOS with the given parameter CPND in q931?
IOS (tm) 5300 Software (C5300-IS-M), Version 12.2(11)T8, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Wed 26-Mar-03 17:04 by hqluong
Image text-base: 0x60008938, data-base: 0x612DC000
ROM: System Bootstrap, Version 12.0(2)XD1, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
BOOTLDR: 5300 Software (C5300-BOOT-M), Version 12.0(4)T1, RELEASE SOFTWARE (fc1)
VGW2 uptime is 6 days, 7 hours, 53 minutes
System returned to ROM by bus error at PC 0x609445F0, address 0xDEADBEF7 at 09:43:46 MSD Thu Apr 6 2006
System restarted at 09:44:45 MSD Thu Apr 6 2006
System image file is "flash:c5300-is-mz.122-11.T8.bin"
cisco AS5300 (R4K) processor (revision A.32) with 131072K/16384K bytes of memory.
Processor board ID 21662873
R4700 CPU at 150Mhz, Implementation 33, Rev 1.0, 512KB L2 Cache
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Primary Rate ISDN software, Version 1.1.
Backplane revision 2
Manufacture Cookie Info:
EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x30,
Board Hardware Version 3.1, Item Number 800-2544-03,
Board Revision D0, Serial Number 21662873,
PLD/ISP Version 0.0, Manufacture Date 16-Jul-2000.
1 Ethernet/IEEE 802.3 interface(s)
1 FastEthernet/IEEE 802.3 interface(s)
128 Serial network interface(s)
4 Channelized E1/PRI port(s)
60 DSP(s), 120 Voice resource(s)
128K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
8192K bytes of processor board Boot flash (Read/Write)
1 REPLY
Re: CPND Paramter q931 with Cisco AS5300
Hi !
Provide us config and log of such call with "debug isdn q931" configured.
156
