cptone does not work
admin_2
Level 3
Level 3
I'm want to find solution for two problems on CISCO2600 IOS, voice functionality:
1) an CISCO IP-Plus IOS that give possibility to configure "forward-digits" on Dial-peer voice x pots and VOFR functionality;
2) an CISCO IP-Plus IOS that have realy working a cptone in italian. In all software that i have this configuration (cptone=IT) gives US tones.
IOS tested:
is-mz_120-5.t1
is-mz_120-5.xk1
is-mz_120-7.t
(_)is-mz_120-7.wk1
(_)is-mz_120-8
(_)is-mz_121-5.t6
_= this IOS, also, doesn't have VOFR implementation.
Not applicable
12.0(7)T and 12.0( 8) are very old images and i would not recommend the use of it. Also 12.1(5)T6 is a deferred image and you should move away from that image.
I checked 12.1(5)T7 for you and it works just fine. Upgrade to 12.1(5)T7 or 12.2 images.
c2600-1(config-voiceport)#cp ?
locale 2 letter ISO-3166 country code
AR Argentina IN India PE Peru
AU Australia ID Indonesia PH Philippines
AT Austria IE Ireland PL Poland
BE Belgium IL Israel PT Portugal
BR Brazil IT Italy RU Russian Federation
CA Canada JP Japan SA Saudi Arabia
c2600-2(config)#dial-peer voice 234 ?
pots Telephony
voatm Voice over ATM
vofr Voice over Frame Relay
voip Voice over IP
c2600-2#sh ve
00:01:39: %SYS-5-CONFIG_I: Configured from console by consoler
IOS (tm) C2600 Software (C2600-IS-M), Version 12.1(5)T7, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/cgi-bin/ibld/view.pl?i=support
