CPU Usage: 100% - CCM 3.2(2c)
Hi, everybody
Our CCM 3.2(2c) goes often to CPU Usage 100%, and don't leave it.
We think that is caused by the Cisco Telephony Call Dispatcher service.
We stop and start the service and the CCM goes ok, for about 8/9 hours.
Are any way to avoid this situation?
Thanks in advance
MP
Re: CPU Usage: 100% - CCM 3.2(2c)
Which SP have you installed?
We had such problems with the attandand console, there were not all phones assigned to the ac user, which user have used the console.
Maybe thats your problem too.
The failure occurs at the moment, this attandand console has been started.
August /NTS
Thanks for your help
Our CM is 3.2(2c) Service Pack F
We do have CM with Active Directory integrated
In fact we can't see in the Web Attendant the list of the users
kr
MP
Bronze
Are you using the Web Attendant application? I had an instance that a user was not setup properly for it, and the application would go into a "retrying" for "call control" status. This would max the CPU and would not go down until we closed the app. I resolved it by setting the user up properly (binding to the AC user).
Geoff
The problem was noticed before weinstalled and start using the Web Attendant.
Thanks in advance for your help
MP
Silver
What process in the Task Manager shows the highest cpu usage?
90
