CRA 3.03 Monitoring and recording issues
I'm trying to get Silent Monitoring and Call recording working on CRA 3.03 and can't seem to get the system to hear or record. Tried to use the "port monitor VLANx" on the port I need to monitor from but it sets its self to VLAN 1 not VLAN 5.
I have the IP Phones on the same switch as the CRA and Call Managers.
Below are the configs, any ideas on what I am missing or need to change?
Thanks.
This is the config running on the 3548's and 3524's
interface FastEthernet0/x----------> Call Manager/CRA/Routers
switchport access vlan 5
interface FastEthernet0/xx----------> IP Phones on these
switchport mode trunk
switchport voice vlan 5
switchport priority extend trust
interface GigabitEthernet0/x----------> Links to 3508 or other 35xx
interface VLAN1 ----------> Data LAN
no ip address
no ip directed-broadcast
no ip route-cache
shutdown
interface VLAN5 ----------> Voice LAN
ip address 172.16.1.30 255.255.0.0
no ip route-cache
ip default-gateway 172.16.1.1
This is the config running on the 3508 connecting all 35xx'x
interface GigabitEthernet0/x ----------> Links to 3508 or other 35xx
no ip address
no ip route-cache
shutdown
ip address 172.16.1.41 255.255.0.0
no ip route-cache
1 REPLY
Blue
Re: CRA 3.03 Monitoring and recording issues
You need to configure the port monitor command on the port the CRS server is connected to (or if you have the Monitoring/Recording installed on a separate server). This needs to be done because the CRS server needs to be sent all traffic in order to monitor/record. Also, if you are using 3550's these do not support bi-directional traffic on a SPAN port so you will need to enable the second NIC on the CRS server and use that for "sniffing"
213
