CRA - script
Hi all,
I've edited a script similar to AA: Accept a call, play welcome prompt and then transfer the call to the Operator or a certain extension ("dial the exension or press 0 for operator"). In case the call is forwarded to a busy extension or to an invalid extension, a prompt is played. But after that, the caller hears a ringback tone and another prompt: "Sorry we are currently experience a system problem..." (there's no such ringback tone and this prompt in my script).
Could anyone give me the solution for this? Thanks!
P/S: I add my script here so anyone could have a look at it.
Re: CRA - script
I am trying to understand what the variblae DP[200] means.
Also, the call redirect step does a blind transfer, so i dont think you will be able to handle any thing in that branch. I would advise using call consult transfer step instead.
Sankar
PS: please remember to rate posts!
Re: CRA - script
DP[200] = 200ms delay
I think the call redirect step does a blind transfer too, but in fact, I have an unexpected result as described and I was confused about it.
Have any other ideas?
Re: CRA - script
The DP[200] is a 200 ms pause, where nothing gets played.
Sometimes that's useful to do in the beginning of a call, since sometimes the prompt you actually want to play starts immediately, while end-to-end audio establishment takes a bit longer (and obviously for other, similar purposes).
Re: CRA - script
I've solved the problem! In the script I posted, when redirecting the call, I didnot terminate it, so the application still held the session and did unexpected things.
Thanks for your relies anyway!
Best regards,
121
