Community Member
create subscriber on demo system
Can I still be able to create subscribers on a demo system - Unity VoiceMail without system key ? Unity comes up but cannot start the AvGaenSvr service - error message indicates system cannot find the file specified. When trying to create subscribers, got message "An unrecognized error has occurred. The new subscriber was not successfully added." Please help. Thank you very much.<br>Duc Vu<br><br>
1 REPLY
Anonymous
N/A
Re: create subscriber on demo system
yes, the demo system allows you to create users. It sounds as though your installation did not go through cleanly and the configuration is hosed up or something. You can disable the AvCsGaen service but I'm guessing there's more wrong under the covers if you were getting a "file missing" error. I'd recommend uninstalling and starting again.
Jeff Lindborg
Unity Technical Lead/Answer Monkey
Cisco Systems
lindborg@cisco.com
http://www.AnswerMonkey.net (new page for Unity support tools and scripts)
82
