Creating IP Phone Background Images
pverstegen
Hi, which graphic tool is the prefered one to create .png files? Phone Designer doesn't work for me and up to now I'm not lucky with MS Paint. Does anyone know? Regards, Peter
Jaime Valencia
I use Paint .NET, you can find it on the web. Free App and a lot of features
java
if this helps, please rate
java
Many Thanks,
I will try and let you know.
Regards, Peter
Yes!!!
It works great.
Resolved my issue.
Many thanks, Peter
