Community Member
CRS 3.0 license and TAPS
Should I need a license to install CRS 3.0 for TAPS only?
Does any CRS (CRA) comes with Callmanager 3.3 CDs?
Community Member
Re: CRS 3.0 license and TAPS
You can use the cut down version that comes on teh Auto Attendant CD with CM3.3(x) for use with TAPS. you are licensed for this with CCM.
D
Community Member
Hi Havid
Have you done it?
The last time I tried (CCM 3.2) cisco told me to install CRA without any feature. In the installation manual they mention CRS and the application repository that the cut version that comes with CCM 3.2 does not have. It is different for CCM 3.3?
Alex
Community Member
Alex,
Not done it yet, but were are nearing the end of a 300 phone install and this is the suggested method from our Cisco Partner.
I will let you know when we have done it.
D
Community Member
Hi Alex
I've installed it with CM 3.3 from the Auto Attendant CD and it works fine. There is a bug to watch out for depending on the version of CM 3.3, if you install 3.3.2 even with SP C the TAPS service doesn't start and keeps stopping, I think it is fixed in 3.3.3. You have to modify the wrapper.properties file to point to the correct java directory. You'll keep getting a prompt saying TAPS is experiencing system proplems every time you dial the TAPS RP.
The file is below. Comment out the entry for wrapper.javabin and add a new line that include the full directory statement.
#THIS FILE IS REQUIRED TO RUN TAPS SERVICE.
#DO NOT MODIFY OR DELETE CONTENTS.
wrapper.bat_home=c:\ciscowebs\bat
wrapper.taps_home=$(wrapper.bat_home)\taps
wrapper.tomcat_home=$(wrapper.taps_home)
wrapper.server_xml=$(wrapper.taps_home)
wrapper.window_home=C:
wrapper.stdout=$(wrapper.taps_home)\TAPSService\TAPSSrvOutPut.log
wrapper.stderr=$(wrapper.taps_home)\TAPSService\TAPSSrvError.log
#wrapper.javabin=$(wrapper.taps_home)\bin\java.exe
wrapper.javabin=C:\Progra~1\Cisco\JRE\j2re1.4.0_01\bin\java.exe
wrapper.class_path=$(wrapper.taps_home)
wrapper.class_path=$(wrapper.taps_home)\bat.jar
wrapper.class_path=$(wrapper.window_home)\winnt\java\lib\DirUser.jar
wrapper.startup_class=TAPS
wrapper.cmd_line=$(wrapper.javabin) -classpath $(wrapper.class_path)
$(wrapper.startup_class)
149
