CRS 3.02 Installation problem
I am trying to install CRS 3.02 on a 7835 server. I am using the supplied CD's to rebuild the server and then try and install the CRS software. During the initial install of CRS, it asks for my license key which works just fine. I am able to get through all of the questions according to the setup documentation. I get through the first CD in 5 to 10 minutes. The second CD stays in for the next 3 hours before the installation finally fails. I have tried this three times, including re-imaging the entire server with the supplied CD's and gotten the same results. Any ideas?
Re: CRS 3.02 Installation problem
Never mind... Bad CD-Rom drive.
Well it may be the problem with the licensing file.
Before you start the install, go to my comupters right click and go to the advanced properties and slect the environmental varibles and set the path in the system varibles filed to point to the path where your license file is.
You shoudl be all set.
Raj.
97
