12-15-2003 10:33 AM - edited 03-13-2019 03:01 AM
Is CCM 3.3.3sr3 compatible with CRS 3.1.2 sr2. If not what latest CCM 3.3.3 service release is compatible with CRS 3.1.2 sr?, Thank you for the info.
12-15-2003 07:29 PM
you can check the compatibility matrix by the following link:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/ccmcomp.htm
12-16-2003 08:17 AM
Yep, I did check that the only issue is that it was last updated on 9/12/03. Cisco Support is researching the info. They do'nt have any doc. supporting the same. Thx
01-11-2004 11:16 AM
Hi.. I am about to proof of concept this in the lab. I'll be upgrading my CCM 3.3(3)sr2 to sr3, while keeping my CRA 3.1(2)sr2.
Has anyone heard anything from Cisco if there are any quirks with this setup yet? Thx.
Lee
