09-18-2002 06:17 PM - edited 03-12-2019 08:50 PM
Hi -
I understand from reading the install information on the Agent/Supervisor desktop requirements for ICD 3.0, that a VoIP monitor server is used both for recording calls and to permit the supervisor to enter an existing session between an agent and caller. I also see the screen that is referenced during the CRS 3.0 install where this information is keyed in. Is this information required during the CRS 3.0 install or can it be skipped? Our plans are to install CRS 3.0 and the enhanced version of ICD. I'd like to get ICD operational, then perhaps later consider implementing the VoIP monitor. It would help to know whether or not I need to configure this before I can use ICD.
Also, there is scant information about the VoIP monitor server and other servers in the CRS installation guide. Do these run as work servers on the CRS server? Where could I go to learn more about them and their requirements?
Thanks, Ginger
09-25-2002 11:06 AM
You should be able to skip that and go back and set it up later, but to be sure check with Cisco.
Here's a link with some info on the silent monitor server requirements:
http://www.cisco.com/warp/partner/synchronicd/cc/pd/cucxsw/icm/prodlit/abtub_ds.htm#xtocid35
09-25-2002 11:58 AM
Hi -
Thank you for your reply. I was not able to access the URL to provided using my CCO login/password. It said I was not authorized or browser could not send authentication information. I am using IE 5.5 SP2. Could it be that I need to be a partner to access this site?
09-26-2002 01:32 AM
I can give you the information you need, just mail me at rif.kiamil@jjfastfood.com
