cRTP and QoS
I am currently designing an MPLS VPN that will be carrying (Cisco) voice via ADSL tails. I have been looking into using cRTP compression but still need to keep the ToS field visable so that the Voice packets can get mapped into the correct MPLS Class (exp bits)
can anyone confirm if the compressed header still provides this means, i dont think it is possible but wanted to sound it out on here
1 ACCEPTED SOLUTION
Re: cRTP and QoS
You can use the qos pre-classify command. This allows the egress port of the router to look at the unencrypted packets (it makes a copy of the original packet before encrypting it).
The issue will be in where you use the command. For GRE and IPIP tunnels, you place it under the Interface Tunnel. For L2F and L2TP you place it under the Interface Virtual-Template. For IPSEC you place it under the Crytpo-Map.
Once enabled, you can do all your standard QoS commands.
1 REPLY
Re: cRTP and QoS
118
