03-11-2002 11:21 AM - edited 03-12-2019 02:46 PM
Since you can't do cRTP on Ethernet in a topology such as this is the only option to bring the PRI directly to the 7200? Just confirming..Thanks.
PBX----3640-1 -----Ethernet------7200-----Frame--- Relay-----3640-2----PBX
03-19-2002 07:12 AM
I think you're right.
03-19-2002 04:24 PM
Why not to bring PRI directly to 3640 and save on 7200?
What is the speed on access to FR?
I also presume that you still need to deploy QoS (ie LLQ on 7200) in addition to cRTP.
Vakhtang.
03-22-2002 05:35 AM
You just need to do CRTP on both ends of the frame link (between 7200and 3640-2. You don't need to change topology. You should also do llq on 7200 and 3640-2 setting up a priority queue for voice, and do traffic shaping and frame relay fragmentation as necessary
