CSCdu51334 and IOS question
I believe I have run into the bug CSCdu51334. TAC advised us to go to 12.2(7a) however this does not have SRST in it. does 12.2(8)T have the fix for this bug in at as well as SRST. I looked at feature navigator and it tells me that 12.2(8)T has SRST. Hope that's correct.
Marcus
1 REPLY
Re: CSCdu51334 and IOS question
That bug was fixed in versions 12.2(5.5)T 12.2(5.6) 12.2(5.6)T 12.2(5.7)S 12.2(5.6)PI 12.2(5.7)DA 12.2(6.4)PB 12.2(6.4)B
So there you can see that it was fixed in interim build 12.2(5.6)T, so this correction must be integrated in the following maintenance releases such as 12.2(8)T
so I think you can go ahead and try it, yet this bug doesn't show up in the caveats resolved for that version... http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cavs/122tcavs.htm
but, well I think it must be integrated in the version you wanna try. Also you can ask the TAC engineer who helped you.
Good luck!
104
