Thanks for the quick response. Below is the output for the recommended commands.
Starting diagnostic test(s)
test - ntp_reachability : 5 second(s) left
test - ntp_reachability : 0 second(s) left
test - ntp_reachability : Passed
Diagnostics Completed
The final output will be in Log file: platform/log/diag5.log
Please use 'file view activelog platform/log/diag5.log' command to see the output
admin:utils diagnose module ntp_clock_drift
Log file: platform/log/diag1.log
test - ntp_clock_drift : 5 second(s) left
test - ntp_clock_drift : 0 second(s) left
test - ntp_clock_drift : Passed
The final output will be in Log file: platform/log/diag1.log
Please use 'file view activelog platform/log/diag1.log' command to see the output
admin:utils diagnose module ntp_stratum
Log file: platform/log/diag2.log
test - ntp_stratum : 5 second(s) left
test - ntp_stratum : 0 second(s) left
test - ntp_stratum : Passed
admin:show process load cpu
top - 11:11:25 up 217 days, 12:38, 1 user, load average: 0.55, 0.49, 0.44
Tasks: 262 total, 1 running, 261 sleeping, 0 stopped, 0 zombie
Cpu(s): 13.9%us, 8.3%sy, 1.9%ni, 75.6%id, 0.0%wa, 0.0%hi, 0.2%si, 0.0%st
Mem: 5994288k total, 5861108k used, 133180k free, 188892k buffers
Swap: 2064284k total, 1281080k used, 783204k free, 2402956k cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
2588 root 20 0 121m 9052 6560 S 1.9 0.2 61:35.98 CiscoSyslogSubA
12039 Admin 30 10 432m 64m 14m S 1.9 1.1 0:02.25 java
14436 openspee 20 0 141m 5224 1596 S 1.9 0.1 1206:48 NSSserver
17074 Admin 30 10 15168 1336 900 R 1.9 0.0 0:00.01 top
20849 cumbxsyn 30 10 453m 179m 7256 S 1.9 3.1 7717:36 CuMbxSync
24408 jetty 20 0 1194m 97m 2632 S 1.9 1.7 707:52.66 jetty
25610 ccmservi 20 0 697m 93m 5364 S 1.9 1.6 893:55.40 amc
28887 informix 20 0 721m 374m 374m S 1.9 6.4 8974:44 unityoninit
1 root 20 0 19492 1628 1200 S 0.0 0.0 19:00.49 init
2 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kthreadd
admin:file view activelog platform/log/diag2.log
06-19-2018 11:10:03 Diagnostics Version: 1.0.0
06-19-2018 11:10:03 getting hardware model [/usr/local/bin/base_scripts/sd_hwdetect HWModel]
06-19-2018 11:10:03 Hardware Model: VMware
06-19-2018 11:10:03 getting verson number [rpm -q --nodigest --nosignature master | sed -e "s/master-//"]
06-19-2018 11:10:03 Version: 11.0.1
06-19-2018 11:10:03 disk_space: Is valid module: True
06-19-2018 11:10:03 disk_files: Is valid module: True
06-19-2018 11:10:03 service_manager: Is valid module: True
06-19-2018 11:10:03 tomcat: Is valid module: True
06-19-2018 11:10:03 tomcat_deadlocks: Is valid module: True
06-19-2018 11:10:03 tomcat_keystore: Is valid module: True
06-19-2018 11:10:03 tomcat_connectors: Is valid module: True
06-19-2018 11:10:03 tomcat_threads: Is valid module: True
06-19-2018 11:10:03 tomcat_memory: Is valid module: True
06-19-2018 11:10:03 tomcat_sessions: Is valid module: True
06-19-2018 11:10:03 tomcat_heapdump: Is valid module: True
06-19-2018 11:10:03 validate_network: Product specific XML file: /usr/local/platform/conf/cli/cliProduct.xml
06-19-2018 11:10:03 validate_network: val: true
06-19-2018 11:10:03 validate_network: Is valid module: True
06-19-2018 11:10:03 validate_network_adv: Is valid module: False
options: q=quit, n=next, p=prev, b=begin, e=end (lines 1 - 20 of 43) :
06-19-2018 11:10:03 raid: getting cpu speed [/usr/local/bin/base_scripts/sd_hwdetect CPUSpeed]
06-19-2018 11:10:03 raid: CPU Speed: 2400
06-19-2018 11:10:03 raid: model = VMware
06-19-2018 11:10:03 raid: Is valid module: True
06-19-2018 11:10:03 system_info: Is valid module: True
06-19-2018 11:10:03 ntp_reachability: Is valid module: True
06-19-2018 11:10:03 ntp_clock_drift: Is valid module: True
06-19-2018 11:10:03 ntp_stratum: Is valid module: True
06-19-2018 11:10:03 sdl_fragmentation: Is valid module: True
06-19-2018 11:10:03 sdi_fragmentation: Is valid module: True
06-19-2018 11:10:03 ipv6_networking: IPV6INIT=no
06-19-2018 11:10:03 ipv6_networking: IPv6 initialized: no
06-19-2018 11:10:03 ipv6_networking: False
06-19-2018 11:10:03 ipv6_networking: Is valid module: False
06-19-2018 11:10:03
06-19-2018 11:10:03 --> executing test [ntp_stratum], fix: fixauto, stop on error: False
06-19-2018 11:10:03
06-19-2018 11:10:03 ntp_stratum: ------------------
06-19-2018 11:10:03 ntp_stratum: Analyzing the stratum level of the Syncing NTP Server...
06-19-2018 11:10:03 ntp_stratum: Executing command /usr/local/bin/base_scripts/ntp_check_stratum.sh -D -f /tmp/tmpz6ZdDX.ntp
options: q=quit, n=next, p=prev, b=begin, e=end (lines 21 - 40 of 43) :
06-19-2018 11:10:03 ntp_stratum: return code is: 0
06-19-2018 11:10:03 ntp_stratum: result: 0, message: Passed
end of the file reached
