Community Member
CUCM 4.2 DevicelistX problem
Hi all,
I am using the DeviceListX function of the CUCUM 4.2 to generate a report. This has been working for a long time, but recently I noticed something strange:
All the phones with a MAC address that starts with SEP002 are not listed in that list. For as far as I know these are the newer type of IP Phones. All the older phones (SEP001....) are shown in the returned XML.
Does anyone know about this behavior?
Thanks in advance,
Michiel
1 ACCEPTED SOLUTION
Community Member
Re: CUCM 4.2 DevicelistX problem
Open devicelistx.asp in a notepad and look for supporting phone models. Update the list to reflect new phones. Here is one some what recent list:
supportedPhones[supportedPhones.length] = 34; // 7910
supportedPhones[supportedPhones.length] = 35; // 7960
supportedPhones[supportedPhones.length] = 36; // 7940
supportedPhones[supportedPhones.length] = 30018; // 7970
supportedPhones[supportedPhones.length] = 30002; // 7920
supportedPhones[supportedPhones.length] = 20003; // 7905
supportedPhones[supportedPhones.length] = 30022; // 7912
supportedPhones[supportedPhones.length] = 30041; // IP Communicator
supportedPhones[supportedPhones.length] = 206; // 7911
supportedPhones[supportedPhones.length] = 115; // 7941
supportedPhones[supportedPhones.length] = 30044; // 7961
supportedPhones[supportedPhones.length] = 119; // 7971
//CSCsb15170 CM: need support for new phones in devicelistx.asp file
supportedPhones[supportedPhones.length] = 207; // 7961G-GE
supportedPhones[supportedPhones.length] = 208; // 7941G-GE
supportedPhones[supportedPhones.length] = 264; // Cisco 7921
supportedPhones[supportedPhones.length] = 335; // Cisco 7965
supportedPhones[supportedPhones.length] = 336; // Cisco 7975
supportedPhones[supportedPhones.length] = 303; // Cisco 7962
supportedPhones[supportedPhones.length] = 333; // Cisco 7942
supportedPhones[supportedPhones.length] = 334; // Cisco 7945
Community Member
Community Member
Thanks, I will test this as soon as possible.
Could you let me know how you found these new "codes" for newer ip phones?
Would it also be possible to add support for the ATA devices or any non SEP??
Thanks in advance
Community Member
Since we develop ad-on products to complement Cisco solution, we had to use devicelistx.asp and/or AXL/SOAP and ran into the same problem. We have modified devicelistx.asp to retrieve phone extensions and new phone models.
Community Member
Yes I do understand that.
But what I ment was where did you got those new "codes" to update the devicelistx.asp
Is there somewhere on the Cisco website such a list or how did you found out?
Community Member
We have a Cisco Developer Support contract and may have gotten it from them. Not sure exactly where we got the codes.
Community Member
Hi Mike,
you see this value inside the database. Just add a phone of the type you are looking for and then look inside the db.
I wrote an application to extract hardware phone via AXL at CUCM 6.1 - simplar report like devicelistX.asp - and that had the same problem.
The model is inside the tkProduct column.
Kind regards
Axel
Community Member
Thanks all!
I have updated the list with the new codes and all the new(er) phones do show up now.
Michiel
217
