Community Member
CUCM 8.5 - CUBE - Avaya IP Office 406 using SIP
Hello
I am having issues with the above setup.
Everything works fine when you place a call from the Call Manager to the Avaya, but when the Avaya initiates the call, it drops after 10 minutes.
It is almost exactly 10 minutes after the initial SYN message is sent that the CUBE Router sends a FIN.
I have tried changing the various timers, but they have had no effect.
Thanks in advance
Mal
Here is a copy of the CUBE Config:
version 15.2
service password-encryption
hostname BH_VG2921
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.152-1.GC1.bin
boot-end-marker
card type e1 0 0
aaa new-model
aaa group server radius RADIUS-SERVERS
server 10.0.0.77 auth-port 1812 acct-port 1813
aaa authentication login default group RADIUS-SERVERS local
aaa authorization exec default group RADIUS-SERVERS local
aaa session-id common
clock timezone gmt 0 0
clock summer-time bst recurring last Sun Mar 2:00 last Sun Oct 2:00
network-clock-participate slot 1
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-participate wic 2
network-clock-select 1 E1 0/0/0
no ipv6 cef
ip dhcp excluded-address 10.3.1.1 10.3.1.10
no ip domain lookup
ip host CUCM-01 10.3.1.2
ip cef
isdn switch-type primary-net5
voice-card 0
voice service voip
allow-connections sip to sip
signaling forward unconditional
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
sip
  min-se 1200 session-expires 1200
  error-passthru
  asserted-id pai
  early-offer forced
  history-info
voice class codec 1
codec preference 1 g711alaw
voice class codec 100
codec preference 2 g722-64
codec preference 3 g711alaw
hw-module ism 0
hw-module pvdm 0/0
hw-module pvdm 0/1
hw-module sm 1
redundancy
controller E1 0/0/0
pri-group timeslots 1-31 service mgcp
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 10.3.1.1 255.255.255.0
duplex auto
speed auto
interface ISM0/0
ip unnumbered GigabitEthernet0/0
service-module ip address 10.3.1.3 255.255.255.0
!Application: CUE Running on ISM
service-module ip default-gateway 10.3.1.1
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface ISM0/1
description Internal switch interface connected to Internal Service Module
no ip address
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
interface Vlan1
no ip address
ip forward-protocol nd
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 10.3.1.17
ip route 10.0.0.0 255.255.0.0 10.3.1.17
ip route 10.3.1.3 255.255.255.255 ISM0/0
control-plane host
control-plane
voice-port 0/0/0:15
echo-cancel coverage 64
cptone GB
ccm-manager fallback-mgcp
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.3.1.2
ccm-manager config
mgcp
mgcp call-agent CUCM-01 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp profile default
dspfarm profile 1 transcode
associate application SCCP
shutdown
dial-peer voice 1 pots
service mgcpapp
incoming called-number .
fax rate disable
direct-inward-dial
port 0/0/0:15
dial-peer voice 2000 voip
destination-pattern 266[6-9]
rtp payload-type nte 120
session protocol sipv2
session target ipv4:10.3.1.4
session transport tcp
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 2001 voip
destination-pattern 267[46]
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 2602 voip
destination-pattern 2602
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 2682 voip
destination-pattern 2682
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 2689 voip
destination-pattern 2689
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 9 voip
destination-pattern 9T
session target ipv4:10.3.1.2
voice-class codec 1
dtmf-relay rtp-nte
fax-relay ecm disable
no vad
dial-peer voice 802 voip
destination-pattern 802
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 2645 voip
destination-pattern 2645
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 2600 voip
destination-pattern 26..
voice-class codec 1
dtmf-relay rtp-nte
no vad
gateway
timer receive-rtp 1200
sip-ua
no remote-party-id
retry invite 2
gatekeeper
shutdown
telephony-service
service dnis overlay
service dnis dir-lookup
max-conferences 8 gain -6
transfer-system full-consult
directory last-name-first
banner login ^CVoice gateway router^C
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 131
no exec
transport input all
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
scheduler allocate 20000 1000
ntp source GigabitEthernet0/0
ntp server 10.0.0.77
end
Everyone's tags (5)
I am not sure if this helps but have you check the ccm service parameter timeout values ?
Also did you check the timeout values on the gateway, check the below link , maybe it can be useful.
http://www.cisco.com/en/US/docs/ios/12_3t/voice/command/reference/vrht_t2_ps5207_TSD_Products_Command_Reference_Chapter.html#wp1643348
Amer
Community Member
Re: CUCM 8.5 - CUBE - Avaya IP Office 406 using SIP
I had the same issue with a sip trunk and had to configure mid call invites within a sip profile that you attach to sip under voice service voip. Do a search for these tags and they should come up. Reply to this post if you cant find them and i can post when im back in the office
1800
