Hall of Fame Super Silver
CUE connectivity issues
I have CUE 2.1.3 on 2821 router, which was working fine until I upgraded the IOS of the router to 12.4 and upgraded the CME to 3.3.
I can not ping the service-module from anywhere except the router, thus I cannot connect to the web GUI. I've tried using unnumbered IP as well as an IP address. I can ping the service-engine IP fine, any clues?
Chris
Re: CUE connectivity issues
Have you set a default route for the ip address of the service-engine ?
if CME is 10.1.11.4 and service engine has ip address 10.1.11.5 which is entered using command,
int s0/0
service-module ip address 10.1.11.5 255.255.255.0
service-module ip default-gateway 10.1.11.4
you also need a static route to 10.1.11.5 as follows.
ip route 10.1.11.5 255.255.255.255 service-engine0/0
Is this route in place ?
I have default route, the static route is only required when unnumberd IP is used.
What is the Ethernet port on the NM-CUE used for, I have nover plugged it in, is it necessary?
Chris
133
