m
CUE integrate with CCM4.2, MWI not working
The message waiting indicator is not showing on the ip phone .But if I dail the VM number, it informs me that I got new voice message and also I can retrieve the voice message. All CTI ports, route point are regestered with Callmanger.
Wondering if I need to set up MWI numbers in the CUE. but based on this document http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_tech_note09186a008027fa9f.shtml
For Cisco CallManager integrations, the Java Telephony Application Programming Interface (JTAPI) protocol lights a lamp directly.
Appreicate any ideas
Re: CUE integrate with CCM4.2, MWI not working
No, you don't need MWI numbers, but the promblem most likely is that the calling search space for the JTAPI ports are not allowed to dial the DN which it's trying to light the lamp for. I.e. if DN 1234 in Partition Line1 gets an MWI, the Calling Search Space of the CTI ports (it may even only be port 1, but for consistency, I'd do them all) needs to be able to dial 1234.
m
Thanks marschne.
Currently, I put all the CTI ports in Calling search space None, which should allow the CTI ports to access all the CSS
Thanks again for you prompt reply
If the CSS is None, then the ports will not be able to call any DN that is a partition other than the None partition.
Do you have to have the "mwi-line x" command?
133
