CUE to CUE networking
I have two CUE modules networked together via VPIM. I can send messages between the two modules, by blind addressing without any problems. When I try to send a message by "Spell by location", it doesnt work. What is the correct procedure for sending messages via spell by location.
CUE 1 - Location name A - Abbreviation A
CUE 2 - Location name B - Abbreviation B.
How do I select a user "John Doe" @ ext 8001 at CUE 2, added as a remote user in CUE 1 ? I want to select this user by specifiying the name of the location and then the name of the user. Is this possible ?
1 REPLY
Re: CUE to CUE networking
The two CUE modules do not share a common directory of names. With VPIM there is the ability to "learn" the recorded names of the remote user. CUE has a cache of 50 (I think that's the case on both the AIM and NM) name entries that are overwritten in a least recently used fashion. You can also add permanent entries of users at the remote location manually via the CLI ("remote user ...").
125
