CUPS filter with exclusion
I'm facing a problem using LDAP requests with CUPC and a filter into the Search Context.
Several weeks delay can occur between the employee's departure and the sAMAccountName deletion.
So I would like to filter these former employees.
The LDAP field userAccountControl is the only one that is common to these "old" Windows accounts.
This string is working but shows old accounts
;(&(objectClass=inetOrgPerson)(AccountType=standard)(employeeID=*))
This string does not work at all with CUPC but works with a standard LDAP query software.
;(&(objectClass=inetOrgPerson)(AccountType=standard)(employeeID=*)(!userAccountControl:1.2.840.113556.1.4.803:=2))
Is exclamation mark a supported character ?
Thanks for help.
  • Other Collaboration Voice and Video Subjects
1 REPLY
Re: CUPS filter with exclusion
Update
The value userAccountControl:1.2.840.113556.1.4.803:=2 is understood by CUPC
(explanation about userAccountControl attribute http://support.microsoft.com/?id=269181)
If I delete the exclamation mark, I can find only disabled accounts with CUPC search field.
Is exclamation mark a supported character ? Or can I replace it with another expression ?
296
