Custom MoH for SRST?
Could someone point me to a document that outlines how to create a custom .au file for MoH from a router in SRST mode?
Thanks in advance!
1 ACCEPTED SOLUTION
Re: Custom MoH for SRST?
Here is a great document that details the configuration on the CCM server as well as on the router. Please keep in mind, if you only want to use this file on the router in SRST mode, don't configure the portion for the CCM. The portion for the CCM tells the CCM to use this file extensively for this location. This keeps the music from having to traverse the WAN in order to hit the local phones. To me, if your software IOS supports this, you might want to look at doing it.
The first URL is for both CCM and SRST router, the second is only the SRST router config:
http://www.cisco.com/en/US/customer/products/sw/voicesw/ps556/products_tech_note09186a00801da5b8.shtml
http://www.cisco.com/en/US/customer/products/sw/iosswrel/ps5012/products_feature_guide_chapter09186a0080181322.html#1332794
Thanks much! The key was the first document. I wasn't sure if I could use a .wav file, or more importantly a .wav file from CCM MoH. I'm happy to see i can!
Oops, I misread your question. You want to create the .au file? Why don't you use the .wav format? It can use both. If you use the .wav then you can have CCM traslate the file for you and then copy the file from the Program Files\Cisco\MOH directory to your local flash to use...
118
