Custom speed dialer service - how to dial the phone? CiscoIPPhoneExecute?
I have a CiscoIPPhoneInput page that accepts a numeric code - it submits to a page that pulls the appropriate phone number to dial out of a database. Once I've looked up the number, how can I get the phone to dial it?
CiscoIPPhoneExecute seems like it might be what I need, but I can't very well POST back to "http://.../cgi/Execute" at that point.
Re: Custom speed dialer service - how to dial the phone? CiscoIP
I sure wish there was an IP phone application-type forum here to make these kinds of issues stand out more.
Surely someone knows the answer!?
I do have a good ASP application to work as an Speed Dial.
If you wanna i can send it to you by mail.
Joao Vitor
Silver
Hi Joao Vitor,
Can I get a copy as well please?
Many thanks
Marina
kmarina@il.ibm.com
Please send a copy to me as well. mailto:edward_b_lovell@fanniemae.com
Could I also Get a Copy. Thanks in Advance.
tim.redpath@metavante.com
What I would do is display a page with the number on so the user can check it before it's dialed then press a softkey to dial the number
The following will dial 1009 if the first softkey is pressed or allow you to edit 1009 before you dial if you press the second softkey
Results
Options
1009
Dial
Dial:1009
EditDial
EditDial:1009
Exit
SoftKey:Exit
If your using asp then all you would do is replace 1009 with <%=Response.write(strNumber)%> where the strNumber variable contains the number from the database that you want to dial.
strNumber="1009"
Results
Options
<%=Response.Write(strNumber)%>
Dial
Dial:<%=Response.Write(strNumber)%>
EditDial
EditDial:<%=Response.Write(strNumber)%>
Exit
SoftKey:Exit
Wes
P.s. i haven't tried the above code it was typed from memory with no phone to test it on, I apologise if there are any XML Parser errors
281
