Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
D41 E pci and D41ESC
I have Unity 2.246B126. There are two 4 port Dialogic D41ESC in the system. I want to add a D41 E PCI to the system. Would this work.... <br><br>Sean Poure<br>NEC-Voice Engineering<br>Sr. Aplication Engineer<br>714 4846275<br>
Sean Poure
Anonymous
N/A
Re: D41 E pci and D41ESC
Sean,
The D41E PCI is compatable with the following boards: D/160SC-LS, D/41EPCI, D/120JCT. The D41Ds and NMS cards are the ones that don't play nicely with other types of cards.
Jami Stewart
Cisco Systems
Although Jami's list doesn't mention the D41ESC board, this shouldn't be a problem. The only thing to note is that your SC boards are connected with a PEB cable while the PCI board requires a CTBus cable. To connect the D41EPCI board to the D41ESC ISA board via the CTBus. There is an optional CTBus/SCbus adapter available from Dialogic.
139
