DB Read Step in CRA
I need to use the value of a variable defined in the variable pane of the CRA editor, inside the SQL statement of a DB Read step, to complete a SELECT query. Is there a way to perform this kind of query?
example:
z is string variable defined in the variable pane of the application.
In the DB read SQL satement we will use:
Select * from mytable where myvariable = z
Reagards,
Ziad KASSAB
Network Engineer
BANQUE AUDI S.A.L.
1 REPLY
Re: DB Read Step in CRA
Please use developer support central http://www.cisco.com/warp/public/570/avvid/ for application development issues.
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
122
