Community Member
DBExport Tools for Unity 4.03
Hi, my client is looking for the tools for backing up the subscribers' greeting, name and other information on the Unity 4.0(3). Well, I did find the tools DBExporttools3.x (the ciscounitytools put this tool under the Unity4.x) and DBImporttools4.x. However, when I tried to install and run DBExporttools, it told me that this version is for 3.x only and terminate my programme. So I have 2 questions:
1. Is there such a tool DBExporttools for 4.x
2. Should I use this DBExport/DBImport or I just simply use the DiRT backup and restore tools?
Raymond
1 REPLY
Re: DBExport Tools for Unity 4.03
If you read the help file for it you'll see that FullDBExport is not the tool you want - that's for exporting Unity 2.x data and then the corresponding import tool will import the data into 3.x or 4.x versions of Unity.
DiRT is the tool you want to use.
95
