11-12-2003 12:36 PM - edited 03-13-2019 02:32 AM
I am trying to use dbexport3.x to export 2.4.6 database. Per the documentation this should be able to run without stopping Unity or requiring a reboot. When I press the export button, I get the warning: "Warning, this will shut Unity down, do you want to continue?" of course I hit cancel, because I need this do run without shutting down Unity. Any help would be great.
11-12-2003 12:59 PM
Make sure you get the latest version of FullDBExport and Import off www.CiscoUnitytools.com from here:
http://www.ciscounitytools.com/App_full_import_export3x.htm
The updated versions should leave Unity on line by default. If not you can run it with the "/OnLine" command line option to force it, even in the older versions - you should fetch the most updated versions before starting regardless.
11-12-2003 01:28 PM
I already downloaded 4.0.7 but it wasn't working. I used the online switch, and everything worked fine. Thanks for good prompt answers once again.
