Community Member
Default Device Settings
Is there a way to have some settings setup on a phone when it first connects to the call manager.
I would like to be able to setup :
Media Resource Group List
User Hold Audio Source
Network Hold Audio Source
Location
Disable Speakerphone
I would also like to configure defaults when a Line is added such as the Call Forward and Pickup Settings.
1 REPLY
Re: Default Device Settings
How are you going to be adding the devices in the systems via BAT, manual, or auto-registered. Most of the things you want to assign are can be done at the device pool level. So if you use any of the methods above and put these devices in the same device pool you should be able to accomplish this. I know you can use BAT to set the speakerphone disabled.
Hope this helps,
-Mckee
85
