Default rules not working
The Call routing rules seems to have some issues. I tried to use configmgr to reload the default rules from DefaultRules.dcs but it returned an error in the event log.
Error Event ID:1050
CoCreateInstance for the Ruler failed.
Any idea how to fix that.
-Boris
1 REPLY
Re: Default rules not working
Which version of 2.x is this? Does that error come up when you try to reapply the default rules or after your reapply them and try to start Unity? Presumably when you start Unity... just checking to be sure.
I've seen that error before when the ruler doesn't like the format of the ROUTING.RUL file which is under \commserver\support directory.
Try deleting the .RUL file there and reapplying the default routing rules again. If that doesn't work, email me the .RUL file at lindborg@cisco.com and I'll take a look at the format... this is much easier to deal with in 3.x since the rules are stored as records in SQL, the .RUL file format is a tad goofy...
104
