Default Unity System Prompts
Can you change System Prompts to other options...? For instance when Unity prompts to send a message press "2", to review old messages press "3", for setup options press "4", etc.
Can those prompts be changed to accept different numbers? I have a customer that is over 2000 users and we will be implementing a large Unity solution, however, they would like to keep the caller input on prompts to be as close to there present system.....
Gold
Re: Default Unity System Prompts
You can't customize the conversation. Unity does have a second, optional, conversation however. It is similar to the conversation you would get on an Octel.
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_unity/unity30/conv/conv1/
Hope that helps...
Keith
You may wish to change to the Cisco Unity optional conversation, see the following link to the Cisco Untiy System Admin Guide for more details.
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_unity/unity31/sag/sag313/sag_0140.htm#1087083
110
