Deleting and Backing up CDRs issue
i have CM 3.1(4b) and the disk is nearly full with CDR records. I know that there are two ways to delete them (query analyzer) or reduce the number (1500000 cdr's default) of CDRs kept in the system.
1) Is there any way to keep only the last , for example, 4 days CDRs?
2) Is there any reference on how to to backup whole CDR database before deleting the CDRs through query analyzer?
Re: Deleting and Backing up CDRs issue
Hello, step 2 has been solved but i am still wondering how to keep always the last 4 days CDR (only)
Any ideas?
Bronze
First, you need to convert the day/time into Unix Epoch time:
http://www.onlineconversion.com/unix_time.htm
This will give you a string that measures the number of seconds since 1/1/1970.
Now, run this query:
DELETE FROM CallDetailRecordDiagnostic
WHERE callIdentifier IN (SELECT cdr.dbo.CallDetailRecord.origLegCallIdentifier
FROM cdr.dbo.CallDetailRecord
WHERE cdr.dbo.CallDetailRecord.dateTimeDisconnect < ? UNION SELECT cdr.dbo.CallDetailRecord.destLegIdentifier
FROM cdr.dbo.CallDetailRecord WHERE cdr.dbo.CallDetailRecord.dateTimeDisconnect < ?)
DELETE FROM cdr.dbo.CallDetailRecord WHERE cdr.dbo.CallDetailRecord.dateTimeDisconnect < ?
Replace the ?'s with the time string you generated
Thanks, i'll try to do that.
With this way customer has to remove manually the CDRs every -e.g. 8 days-.
Is there are automated procedure for removing the CDRs? (Run it once and never touch it again while it keeps 4 days only CDRs).
Hello again
i tried parsing the following string in order to keep only today's CDRs with a readable time format but an error appeared. The string i parsed (parse query at query analyzer) was:
WHERE callIdentifier IN (SELECT cdr.dbo.CallDetailRecord.origLegCallIdentifier)
WHERE cdr.dbo.CallDetailRecord.dateTimeDisconnect < 1066262400 UNION SELECT cdr.dbo.CallDetailRecord.destLegIdentifier
FROM cdr.dbo.CallDetailRecord WHERE cdr.dbo.CallDetailRecord.dateTimeDisconnect < 1066262400)
DELETE FROM cdr.dbo.CallDetailRecord WHERE cdr.dbo.CallDetailRecord.dateTimeDisconnect < 1066262400
1066262400 corresponds to today's date.
The error that appeared was:
Server: Msg 156, Level 15, State 1, Line 3
Incorrect syntax near the keyword 'FROM'.
Any idea?
Bronze
Did you choose the CDR database in the pulldown list at the top of query analyzer?
Try removing the cdr.dbo from the beginning of each string.
Hello dugrant,
thanks very much. Query was parsed and everything is o.k.
Kind regards
228
作成コンテンツを作成するには してください
