Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
delivery location is not working
Hi ,
I have tried to create new delivery location but failed. Every time I have created but nothing happening from the screen. I am now using Unity 3.1.2 with CCM 3.1. Pls adv. Because of this , I cannot use blind addressing.
Re: delivery location is not working
Not sure what you mean by "nothing happening from the screen". When you go to create a new delivery location object, does the add dialog come up? When you fill in the details and hit add is there any kind of error displayed? Just a blank page? I'm assuming you're creating an SMTP location destination, right?
Hi ,
Yes, I have filled up everything but I can't see anything after pressing Add button. It looks like the same page and it is blank from the page. Pls adv.
Bronze
What kind of delivery location are you trying to add -- AMIS, SMTP, or Bridge?
If you are trying to add a Bridge delivery location, be sure that you have first run ADSchemaSetup to modify the schema for the Bridge.
156
