Community Member
design question
does anyone know a method to achieve this.
user dials 75000 -digit 7 is removed and last 4 digits are sent out of GW 1
if GW 1 is down digiits are sent out GW2
if GW 2 is down digits are sent out of GW3 with the area dialling code prefixed, so 01202 5000
I can't see if you can do an if type config?
Super Bronze
Re: design question
It is almost definately possible - you've not supplied a great deal of info though:
Are you using CM/CME? Or just gateways?
If CM what protocol to manage gateways? h323 or MGCP?
Etc..
It will mean either configuring CM to use RL/RGs with translation patterns, or configuring translation rules on the dial-peers on gateways.
Can help more if you give us the background.
Please rate helpful posts.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Community Member
Re: design question
I am using the following
Callmanager 4.1-3
3 X MGCP gateways
thanks
Community Member
Re: design question
If you have a Cisco IOS Software gateway, a translation rule can be created and applied to the outbound Voice over IP (VoIP) dial peer with preferences. The following is an example configuration:
translation-rule 1
rule 1 ^5000 12025000
dial-peer voice 10 voip
preference 1
session target gw1
dial-peer voice 11 voip
preference 2
session target gw2
dial-peer voice 12 voip
preference 3
session target gw3
translation-rule 1
On Cisco CallManager, make a translation pattern and assing it to route list with prority.
118
