Device Association error
Using Call Manager 4.1(3)sr2. Every time I try to associate my AD username with my phone I get the following error:
Could not update user. 1
Error No: -32
Error Description:
(There is no description).
I have not had this error on any other user except for me! I am the domain admin, and have full administrator rights to the call manager.
Has anyone seen this before?
Todd
1 ACCEPTED SOLUTION
Re: Device Association error
If it’s only one user and you’re using AD, please follow this procedure to fix it:
1) On the AD server go to a cmd prompt and type "mmc" then enter
2) In MMC select Console>Add/Remove Snapin
3) Select Add
4) Scroll down & select ADSI Edit
5) ADD
6) Close
7) OK
8) Right click on ADSI Edit, select Connect to & OK
Then do:
1) Find user in account that can not be updated
2) Right click on user & select Properties
3) Select Property View, scroll down to "ciscoUserProfile" & "ciscoUserProfileString"
4) Remove any value for each view. This will dis associate the user from any Cisco
profile, this is a good thing!!! Probably what happened is that somehow this line has
gotten corrupted.
5) Click OK
6) Find user in Global Directory associate the user with a device.
Green
Hi Todd,
Are you able to search users in CCMAdmin|User|GlobalDirectory ?
You user in AD is located in the same OU as others that are working?
You may gather a sniffer trace from CCM when doing this (Use netmon) and attach it to the post.
//G
Yes I can search users in the Global Directory.
I am in the same OU as others that are working.
Will try sniffer and see what I get.
3) Select Add
5) ADD
6) Close
7) OK
Then do:
gotten corrupted.
5) Click OK
Fixed!
Thanks for the tip!
Todd
135
