DeviceTransientConnection - Transient connection attempt
I have a single phone on a CCM Ver 4.1.3 that is causing several event messages shown below.
Error: DeviceTransientConnection - Transient connection attempt.
Connecting Port: 0
Device name [Optional].:
Device IP address.: 172.30.10.112
Device type. [Optional]: 255
Reason Code [Optional].: 6
App ID: Cisco CallManager
Cluster ID: CLV1WCM01-Cluster
Node ID: 172.30.1.10
Explanation: A connection was established and immediately dropped before completing registration. Incomplete registration may indicate a device is rehoming in the middle of registration. The alarm could also indicate a device misconfiguration, database error, or an illegal/unknown device trying to attempt a connection.
Recommended Action: No action is required if this event was issued as a result of a normal device rehome..
The issue is that when a call is attempted to the DN on the IP side, it is directed to VM. When a call is attempted from outside the IP system, the call is completed to the DN. I also saw this error in a trace.
05/10/2002 08:05:52.667 CCM|ForwardManager - processDbFwdUpdateInd - ERROR - DB_ADD_ENTRY - Entry for Dn= 6717 NOT Added - Record from DB Contains no Forwards, or Group Pickups Number|<CLID::CCM Name-Cluster><NID::XXX.XXX.XXX.XXX><CT::2,100,115,1.3545><IP::><DEV::>
I have moved and tested the connectivity to the phone (local network connection) and also have even changed IP phones with no change in results.
Any Ideas?
1 REPLY
Silver
Re: DeviceTransientConnection - Transient connection attempt
CallManager does not know type of device. This is indicated by "Device type. [Optional]: 255". So first delete the device from CCM and try to register again with CCM. A Reason code of '6' means its connectivity error.
261
