DHCP and Aux/Native VLANs on CCM
I am running DHCP for a 2 subnet lab environment. I have a 36xx router with a 4000 switch serving my Phones, using the PC Port for computer access. I have my 4000 ports setup to use Native VLAN 31 and AuxVlan 30, Ihave two DHCP scopes setup on my CCM, one for each subnet, and the helper address configured in my router. My phones register correctly into my .30.x Subnet, but my PC's are also registering to the same subnet instead of the .31.x.
Anybody have an idea what I am missing? Thanks.
Re: DHCP and Aux/Native VLANs on CCM
mak sure that the port is showing up in both the data vlan and aux vlan when doing a "show vlan"
also make sure that your vlan interfaces on your router are setup properly
if all else fails - put static IPs on devices and troubleshoot from there
Port is showing in both VLAN's. On VLAN 31 (data), I have a helper address pointing to my CCM which resides in the 30 subnet. I did find that the switch port I was working from did not have the 31 VLAN configured, and after setting that "correctly", any DHCP resolution I was getting from that port went away. I have been over the config on the switch and the router and everything "looks fine" but it still not working. Anybody have a working model of this that can post snip of their config?
Sean I can give you a snippet. I have resolved this on both the 4003 and 4006. Which model are you using?
I have one each here, currently trying to resolve on the 4003. Thanks!
Here you go Sean. Any additional questions about this particular config, please contact via email. Notice the 4003 uses one subinterface rather than two.
Catalyst 4006 trunked with 3660
interface FastEthernet0/0
Description Trunk to local LAN
ip address 10.10.96.1 255.255.255.0
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.10.96.1
interface FastEthernet0/0.1
Description DATA VLAN
encapsulation dot1Q 5 native
ip address 10.10.90.1 255.255.255.0
ip helper-address 10.10.90.20
interface FastEthernet0/0.2
Description VOICE VLAN
encapsulation dot1Q 95
ip address 10.10.95.1 255.255.255.0
ip helper-address 10.10.125.10
Catalyst 4003 trunk with 3640
interface Ethernet0/0
Description DATA Vlan
ip address 10.10.115.1 255.255.255.0
ip helper-address 10.10.115.20
h323-gateway voip bind srcaddr 10.10.115.1
interface Ethernet0/0.1
encapsulation dot1Q 118
ip address 10.10.118.1 255.255.255.0
121
